Previous in Forum: Nocera's Electrolysis   Next in Forum: Insulation on wire
Testing Water from an Experimental Desalination Unit
02/26/2010 1:06 PM
We are building an experimental desalination unit. What should I test the product for?
Of course PH, Sodium & TDS (total dissolved solids) but what else? Also any suggestions for instrumentation?
One of our goals is to keep the operating costs at a minimum.
Should mention our process is not Reverse osmosis.
Pathfinder Tags: desalination instrumentation
Re: Testing water from an experimental desalination unit
02/26/2010 2:34 PM
Conductivity too. Purity is inversely proportional to conductivity.
02/26/2010 3:03 PM
If it's water for drinking, test for calcium. If it's under, oh, say 60ppm, re-harden it above 60ppm otherwise it will taste horrible.
If it's water for drinking, do a biological test. E.Coli. Staphylococcus. That sort of thing.
If it's water for drinking, consider adding chlorination units and/or ultraviolet disinfection downstream of it, depending on the qualities of the distribution system.
As for instrumentation and minimising operating costs, well, that all depends on how big it is and how long it runs, which isn't stated in the original posting.
Good Answers: 101
Re: Testing Water from an Experimental Desalination Unit
02/26/2010 9:02 PM
pH, TDS, sodium, hardness, bacteria, suspended particles, temperature, dissolved gases etc. The list will depend upon the application of the water. Assuming that it's Grade E1 water, the purest grade available, it will be all of the above.
A fairly effective way to measure purity is water conductivity or resistivity.
Good Answers: 109
02/26/2010 10:56 PM
Experimental suggests novel. However if it involves distillation be sure to check volatile organic carry over if TOC on raw water is evident. I think PWSlack #2 is a GA. I would add that checking Heterotrophic plate count (HPC) would be a good idea no matter what method of treatment.
If you are using ion exchange you may want to consider amines after anion exchange. Amines can be problematic on start up. Check colour, turbidity, conductivity, pH, alkalinity, SO4 (raw and treated) CO3 (raw and treated) TOC (raw and treated). all parameters may affect treatment process. Have fun and good luck.
Popular Science - Weaponology - RaoTR
02/27/2010 1:01 PM
If you are not using RO, then probably you are using Ion Exchange. Anyways, you should also test for Redox potential, Total Kjeldahl Nitrogen and Phosphates if you are likely to use brackish water.
DVader1000 (1); kevinm (1); Mikerho (1); PWSlack (1); raotr (1)
