Previous in Forum: Parabolic Mirrors for Generating Steam   Next in Forum: Engineering a Revolution - Saratoga: The Battle and the Park
Overunity
02/28/2010 6:09 PM
Imagine having an automobile that run with a "Magnet-Solar-Wind Engine" in a non stop sustainable -GREEN ONLY- alternatives. Well, I guess it is very probable as follow:
A) By strategically positioning strong 'magnetics valves' rigth on front of cylinder head area where it can make turn-flipover-or slide side to side in sync with piston travel up and away from cylinders head as an standard 'Stirling' engine does 90 deg. opposites stroking operation (Volks/Porches Symetrics Also) related with it's crankshaft motion design.
B) The piston will be made of 'magnetics' alloys materials in order to counteract with the 'magnetics valves' in harmonic timing sequences sustainable torque. The fundament of such an engine is the 'repulsion/attraction' effect involved on it's internal counterbalancing magnetics interactions.
C) When in 'magnetics mode' this engine will work on cloudy-rainy-nigthtime-conditions.
D) The 'wind turbine genset' will be modified and addapted to be an integral power plant onboard. This mean it going to be operating by car motion as intake air it being ducted straigth into turbine aspen to make it turn and rotate as car coasting through the road producing enough electric energy to sustain batteries bank constant charged and improve exponentially longer running distances between point A-B and so on.
E) In 'solar mode' the heat from solar cells will be strong enough to make it work something similar to the 'Stirling Engine' modus operandi.
F) The -Wankel- engine model will also be addapted as well with a rotary magnetic field instead somehow like an standard electric motor somehow but with a modified magnetics internal interaction that provide the auto magnetical motion of repeal/attraction natural effect saving batteries bank power to for when is need to sustain engine output constant torque production in a non-stop fashion.
Allset again let me know if you like this 'Brainstorm Idea' and we'll stay in touch here in CR-4 blogs then. Easy Does It! I'll let you go now I have to check on my grandson and the cat around, already Buddy's!
Crank that Puppy-Up,
MC
This discussion was "closed" on 03/01/2010 9:25 AM. No new comments are allowed.
Message from admins:
Over unity bunk
Re: "Magnet-Solar-Wind Engine" Tech.
02/28/2010 7:00 PM
how is that suppose to be effecient or even work?
02/28/2010 7:36 PM
See my reply to your earlier post.
Please stop wasting our time.
02/28/2010 8:17 PM
Most of these concepts have been discussed, explained and covered separately on CR4, and in many cases numerous times over the last few years.
Some (but by no means all) of the latest ones.....
http://cr4.globalspec.com/thread/50683/The-AirRay-Auto
http://cr4.globalspec.com/thread/29763/Put-a-Windmill-Turbine-on-a-Car
As for magnet interaction motors (be they permanent magnets or magnetic field interaction), many, many times.
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=magnet%20motor&order=asc
http://cr4.globalspec.com/thread/5628/The-Perendev-Magnetic-Motor
Same for solar.
The primary idea of replacing the massive force moving a petrol engines pistons with magnets just wont work for the very simple reason (and numerous others I am not going to go in to here) that magnets (be they permanent or electromagnet) cannot produce a similar amount of force necessary to even move the piston to produce the work necessary to move an unloaded engine (let alone one connected to a transmission and a vehicle). It just ends up being yet another free energy design attempting to replace a finite fuel source with magnets which don't seem (at first glance) to run out of magnetism force.
Sorry, no free lunch here.
03/01/2010 1:16 AM
Silliest notion I've ever heard, short of some recent nonsense about IC Engines being less than 1% efficient. A beanie-copter car might be pretty entertaining, though.
I wonder how many different people are producing these posts, or they all different aliases for the same genius?
Register to Reply 4 comments
Over unity bunk
jack of all trades (1); JohnDG (1); phoenix911 (1); Tornado (1)
