Previous in Forum: MPFI Engine   Next in Forum: Fan and Pump Calculations for Cooling Systems
Bottoming and Actuator Pistons
03/01/2010 1:39 AM
The snubber slows the actuator near the end of travel to prevent overshoot and bottoming of the actuator piston. The implementation is relatively simple: position commands from the flight control computer are rate limited in the ARTs, with the rate limits reducing to zero near the end of travel. This controller is mechanized through the rate limiter, described previously.
what does "bottoming" mean here?
I am not a home work cheater. I am a translator seeking professional help
Re: bottoming of the actuator piston
03/01/2010 1:58 AM
This would be the piston actually striking either end of the cylinder. If it did so at full velocity, there would be a significant shock load when it suddenly stopped.
