Previous in Forum: Valve and Flange Class Parameters   Next in Forum: Drill Bit Clearance Angle
Temporary Welded Blanking Plates for Pipe Spool Testing
03/01/2010 1:25 PM
Can anyone tell me how to calculate what thickness of plate is required when blanking off a manufactured open ended pipe. The plates are to welded onto both ends to allow for pressure testing of the item and cut off again afterwards.
Good Answers: 29
Re: Temporary Welded Blanking Plates for Pipe Spool Testing
03/01/2010 3:13 PM
I suggest ASME B16.5
Si vis pacem, para bellum
03/02/2010 10:27 AM
There are portable Hydro-test plugs used for hydrotesting for open pipe ends.
Check into that as well.
More economical than welding, etc.
03/04/2010 8:01 AM
So what happens to the metal that is disturbed during the cutting-off process as regards its suitability after the pressure test? Can the forum assume it is cold-sawn and not burnt off?
Anonymous Poster (1); PMoon (1); PWSlack (1)
