I wanted to know how to calculate the distance using the RSSI data. I think we need to consider things like path loss, antenna gain, etc.
Do you know if there is any derivation or calculation done using all the constraints so that the result is more accurate for the distance computation?
is there a paper which defines or gives details about calculating the RSSI more accurately. Becoz I think directly using the RSSI values for distance estimation could be inaccurate.
