Previous in Forum: UPS Batteries   Next in Forum: 1500-hp Motor Failures
DOL Starter vs. VVVF Drive
03/03/2010 7:01 AM
advantages of vvvf drive against dol starter.
Re: dol starter vs vvvf drive
03/03/2010 7:27 AM
VVVF is a drive (Variable Frequency Variable Voltage)- modified variable frequency drive.
DOL is only a starter.
Good Answers: 29
03/03/2010 8:21 AM
Drives can reduce inrush current. They can manage speed, torque, and up and down ramping at start and stop to suit your application. More options are out there if you look around. Classic motor starters supply current directly to the motor all at once and provide overload protection. That's about it.
Good Answers: 804
03/03/2010 12:55 PM
They are not really comparable. Both start an AC motor
DOL is the most basic form. Fewest parts, highest MTBF, smallest package. No other advantages whatsoever. Biggest disadvantage is highest starting current, highest torque shock to the load, uncontrolled deceleration (coasting).
VFD is the most expensive way to control a motor but changes speed, controls acceleration and deceleration infinitely, something virtually impossible to do any other way. If you do not need to change speed, a VFD is a waste of money (unless you have an extreme starting power limitation to deal with).
Re: DOL Starter vs. VVVF Drive
03/04/2010 3:02 AM
Modulating the speed of a motor using a VVVFD can give energy savings that qualify for capital grants under the Carbon Trust's scheme. Such grants can greatly enhance the payback rate on the investment as well as reducing carbon footprint compared to DOL.
Register to Reply 4 comments
Anonymous Poster (1); JRaef (1); PWSlack (1); RDGRNR (1)
