Previous in Forum: Grade or Thickness   Next in Forum: Caterpillar Engine 3512B - Shutoff
Hydraulic Filter Capacity
03/04/2010 11:10 PM
What governs dirt holding capacity in a hydraulic filter?
Re: Dirt holding capacity of a hydraulic filter.
03/04/2010 11:25 PM
The amount of dirt it can collect and yet leave enough area of the element(s) to allow acceptably high flow at acceptably low pressure difference.
03/05/2010 10:48 AM
Like Tornado said, it will collect dirt until the presser differential becomes excessive and the media collapses or ruptures.
What that means is as the filter becomes clogged with dirt it will block more and more of the liquids flow until a critical point is reached and failure occurs. With some oil filters, there is a by-pass valve, usually a spring loaded plate that will compress and allow the oil to pass even if the filter becomes too clogged; after all to an engine, or hydraulic pump, dirty oil is better than no oil.
Drew
03/05/2010 8:20 AM
A filters Debris capacity is mainly determined by filter media area, porosity and outer shell or container / media capacity. The amount , size and packing characteristics of particulate matter along with fluid composition and contamination particle size greatly reduce usable Delta pressure range. The only true determination of real capacity limit can be determined by pressure drop across filter at a given viscosity. When in doubt change it at factory reccomended time versus operating conditions and enviroment. EDDY
Register to Reply 3 comments
Anonymous Poster (1); Drew K (1); Tornado (1)
