Previous in Forum: Clean Earthing vs. Dirty Earthing   Next in Forum: Transformer Tertiary Winding
Distance Between Cables
03/05/2010 4:36 AM
We have to lay cables for 11 KV/ 132 KV ,80 MVA generator transformer.
We think that 12 runs of 400 sqmm ,3core ,XLPE,Alu cable will be suitablefor 11 KV side on GI trays on Air.We would like to know whether the increase in number of runs will derate the cable.what shall be the distance between one cable and another cable on a horizontal tray. What is the maximum allowable bending radius of the 400 sqmm cable.Can any one give guidance in this regard.
Sriram
Re: sriram
03/05/2010 4:49 AM
Which country code is to be followed?
Ambient conditions?
Re: sriram
03/05/2010 11:06 PM
We are in India .The ambient temprature is from 45 to 48 deg cent.
Sriram
Re: sriram
03/05/2010 11:48 PM
Refer to IS-1255
You may choose any spacing (greater than minimum required as specified in IS) & accordingly your derating factor changes. You may get lesser no. of runs requirement for higher spacing (if you are looking from ampacity perspective only). There are other aspects like voltage drop during normal running, during highest motor starting..
go to any cable manufacturer's website, you will get derating table.
Re: Distance Between Cables
03/05/2010 11:47 PM
Current rating furnished by manufacturers assumes "1 D" (D= Diameter of the cable) between two runs of cable, an ambient of 30 deg.C. You have consider derating due to both. For India, better consider ambient as 50 deg.C. If you decrease the distance between the cable, separate derating applicable. Consult with Cable catalogue / vendor.
It is better if you consider single core cable in tre-foil formation instead of three core cable. This saves cable cost as well as helps in better layout. Usually 3C cable is good upto 240 sq.mm. for easy laying. You may need 6 runs of 1C-630 sq.mm. / Ph only.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
03/06/2010 12:20 AM
For bending radius, if you have single core cable then the radius= 20D and for three phas cable, radius=15D
Where D= overall diameter of the cable(including insulation and everything).
03/07/2010 4:32 PM
Ur free to lay Ur XLPE cable side by side with a slit gap of of 5mm or more to allow for air circulation or one suspended on top of another. The important thing is to allow for free air circulation that enhances heat dissipation.
For the bend, take any bend of appropriate internal radius that will not be injurious to the cable.
Dickson.
There is peace in silence and achievement in plans.
Good Answers: 170
03/09/2010 9:20 AM
As per Clause 5.3 of IS 1255, the minimum bending radius of 11kV Multi core XLPE Cables is 15 D, where 'D' is the over all diameter of the cable.
Though the IS does not specify any spacing between cables laid horizontally on a cable tray, cable manufacturers do give appropriate de-rating factors, for carious cable spacings right from touching to many clearance distnaces. This is given both for horizontal spacing as well as vertical spacing. This has to be referred to and the cable to be de-rated accordingly.
Register to Reply 7 comments
Anonymous Poster (1); Dickson (1); electricalexpert65 (1); nshingate (1); PWSlack (1); sidhu16 (1); thiagusriram (1)
