Previous in Forum: Tapped Exhaust   Next in Forum: Flow Relation for orifice with pipe tappings
what is the function of hall sensor how does it work
03/05/2010 11:44 PM
i wish to know more on this topic as i may have to incorporate this item into my unit having voltage from 0 to 100 volts dc thanks
zakireh
Re: what is the function of hall sensor how does it work
03/05/2010 11:45 PM
03/07/2010 12:36 AM
I believe the Hall Effect sensor (or in the case I used them - a keyboard pushbutton) was basically a movable magnet, when it is pushed through a coil of wire it creates a current that would be sensed as connection/button pushed.
Seems to me it was a little more elaborate than metal leaf in a switch.
03/07/2010 2:01 PM
Hall sensors do detect magnetic fields, but no coil of wire is involved. Check lynlynch's link.
03/07/2010 7:50 PM
The hall effect is often used to produce a sensor that transduces current to a voltage signal that is proportional to the current over a defined range. This is useful for measuring current in a digital environment as voltages are a lot easier to read than currents thanks to ADCs (analog to digital converters). See, for example, LEM (http://www.lem.com/).
03/07/2010 7:42 AM
03/07/2010 7:57 PM
HI!
i have gone through your references and studying the details
THANKS!!
can anybody help me with a designer who can get my job done
zakireh
03/07/2010 10:26 PM
If you would tell us exactly what it is you are trying to accomplish, there is a good chance someone here can and will help.
Hall effect sensors have many applications. Which one(s) is(are) of use to you?
Register to Reply 7 comments
Anonymous Poster (1); dkwarner (2); Instruform (1); lyn (1); Sid_Sidow (1); zakireh (1)
