Dear ALL,
We have air compressor of ATLAS COPCO with Electronikon Display. The motor used in the air compressor is 315 KW at 400 V and the current rating is 540 Amps. The problem is that when the compressor runs in loaded condition the motor gives imbalance of phase currents measured by tong tester. The phase currents on Red and Yellow terminals are 307 Amps while on Blue it is 295 Amps. The motor was already burnt and its winding was done a month before. But we also checked the same condition on the new compressor motor. Kindly suggest me the solution. Also tell the alternatives of options if you have.
Best Regards,
