Previous in Forum: Slider Crank Mechanism   Next in Forum: High Speed Small Conveyor System
Steel for Followers-pad Type
02/02/2007 11:03 AM
I like to make camshaft followers (dia 37mm - fiat 128 ) top whit out shims for racing.I have posibility to use plazma jon nitriding.I can find next steels but i dont knew whot is best for followers.I can find H 13 ;4410/4142 ;6145/6150 end 4340 I need info whot steel can be hardened to cc HRC 60+
Re: Steel for Followers-pad Type
02/03/2007 5:05 AM
Use Alloy Tool Steel to
JIS G4404(1972) Type SKS11(This is Japanese Standard) .Go by Chemical Composition to your Nation's Standard Number
HARDENED+tempered to HRC 62+
CHEMICAL ANALYSIS:C=0.95>1.05,Si max 0.35,Mn0.9>1.2,Cr0.8>1.2,W 1.0>1.5, P,S<0.03 all %
Anneal--780>850C Slow Cooling
Hardening to water from760>810 C
Tempering in air from 150>200C
02/03/2007 9:29 AM
Thenks for info but I have only plazma jon nitriding for treatmentend I cant buy oll steels. Do you sugest ? or advise4340 or 4410 or 6145 or close
Regards sime
02/03/2007 5:07 PM
You will only obtain 60 HRC with tool steel. With 4340 or close, you will obtain 44 HRC when quenched and tempered correctly. And they're not designed for surface treatment as cementation or nitride hardening. You could try the 8620 series, that's a steel easily surface hardened, and you can apply current induced surface heat treating. I'd choose this one, and not a so high strengh steel. THey tend to crack too easily.
Humm... suspicious you are...
02/04/2007 8:25 AM
Thenks again.I use 8620 for gears for gearbox but I will look find C300 maragin piece dia 40mm x500 end I will look rezult?
02/05/2007 5:19 AM
I'd still choose a more ductile material with surface added carbon content and hardening but, if you'd like to spend a good amount of money in the blanket, yes, C300 could work fine. C300 Maraging is a great material, but do not expect to surface treat it, you'll probably not going to obtain the desired treatment, and make it too fragile fro your aplication. If you're gonna use nickel based alloys, you're gonna treat all the material as one. And do not expect to obtain 60 HRC in it. You're gonna have a high strengh material at around 45 HRC. This material is intended to have a high yeld stress value, not to be a hard tool steel, even if hardness and strengh are somehow related.
I doubt you need more than this, anyway.
02/08/2007 10:58 AM
This is undoubtedly the best solution.
You have no great extra gain going to HRC60+.
Anonymous Poster (2); bhrescobar (2); MUKULMAHANT (2)
