I've been doing high voltage experiments for a while using a Spellman SL40PN30 power supply. In that time I've been capturing data using it's 26 pin Input Output board on the back of the unit. I recently tested them to see if they were still in calibration and sure enough they are. As Spellman says, the voltage is supposed to read 10v at 40Kv and the amperage is supposed to read 10v at 750uA. The problem is my Fluke Oscilloscope is showing a large degree of variance in the amperage tracks that rise and fall almost equally into the positive and negative scale.
I used my Fluke Multi-meter to confirm this problem and unlike the Oscilloscope it showed no large variances. Instead it was steady like a rock. So my question is were do these variances come from in a oscilloscope vs. the power supply face meters and Multi-meter measurements. It just makes no sense to me that an Oscilloscope would be less accurate than a relatively inexpensive multi-meter.
