Previous in Forum: control and safety sytem for small skids   Next in Forum: Measurements and Variance
Transmitters
03/09/2010 2:29 AM
what is a transmitter
Re: transmitter
03/09/2010 2:45 AM
Someone asked this same question a day or two ago. Using the "Search all of CR4" button with "tramsmitter" typed into the window will yield about 500 threads on all types of transmitters and related questions. Happy reading!
To speak generally, a transducer is a device that converts a sensed value (pressure, temperature, flow, pH, etc.) into some other well correlated value (voltage, current, pressure, radio signal) etc.) that is easier to send (transmit) to a recording or controlling device.
Transducer and transmitter are somewhat interchangeable terms, but transducer focuses more on the correlation of the two values, while transmitter relates more to the method of conveying the signal remotely.
Re: Transmitters
03/09/2010 11:13 AM
You might also try Wikipedia.
http://en.wikipedia.org/wiki/Transmitter
Re: Transmitters
03/09/2010 12:22 PM
www.google.com
Then in the SEARCH block, type "transmitter". You'll be surprised what the internet holds. This break through in technology can also search other words as well. Dont be shy, google wont hurt you.
Good Answers: 29
Re: Transmitters
03/09/2010 3:34 PM
Beam me up Scotty! Oh! That's a transporter. Sorry
Register to Reply 4 comments
Anonymous Poster (2); RDGRNR (1); Tornado (1)
