Previous in Forum: Ring Lubricator Compressor for Instrument Air Service   Next in Forum: Transmitters
control and safety sytem for small skids
03/07/2010 7:31 AM
what is the proper and optimize solution if you want to control standalone skid for example (pumps and tanks) with very Little control points and more Little shutdown points?
Do we need separate control and safety system for this small system or we use one control system to do both process and safety actions?If so what is the major characteristics of this system?
Is it better to use certified SIL system for both systems ?
Re: control and safety sytem for small skids
03/07/2010 12:17 PM
Sounds like another homework problem to me.
03/07/2010 3:22 PM
This will depend on exactly what the skid contains and what needs to be controlled. More details are needed in order to suggest an optimal control system, especially if hazardous or highly valuable fluids are involved.
03/09/2010 4:51 AM
The skid contains water feed pit ,transfer pump to two tanks and two disposal pumps
the fluid is not valuable it is Produced water
of course the control point will be basically the level of the feed pit & tanks ,the discharge pipe lines pressure and flow and the protection of the pumps and motors
regards
03/07/2010 11:07 PM
Safety (such as E-Stops) should be built into your control program. There is really no better way to do it. Your control program oversees the entire system - it is only logical that all I/O be directed by it, of which the safety system is but a part.
03/08/2010 3:18 AM
Anything that has a personnel safety function needs to be hard-wired fail-safe, and not go via any software.
For pumps and tanks:
  • Consider putting emergency stop buttons and lockable isolators next to each pump.
  • Consider the implications of a wire falling off the terminals: does that high level switch break on high level so as to interrupt the supply to the pump?
  • Consider hard-wired "vital" interlocks on the pumps: a low-level switch that breaks to interrupt the pump power supply when the tank has nearly been pumped dry irrespective of whatever else is going on in the control software, for example.
SIL certification is of no value without the accompanying test documentation.
a_m_shiha (1); Mikerho (1); PWSlack (1); redfred (1); Tornado (1)
You might be interested in: Test Points, Safety Laser Scanners
