Previous in Forum: Composite Repairs for ASME VIII Div I Vessels   Next in Forum: Nozzle Shape and Pressure Decrease
Sizing Worms and Worm Gears
03/09/2010 6:52 AM
how to do initial sizing for worm and worm gear?
Re: worm gearbox
03/09/2010 8:30 AM
depending on application parameters.
Load to be transmitted
Center distance available
speed ratio
Re: worm gearbox
03/09/2010 8:36 AM
2.90 hp @1750 rpm
Ratio is 10:1.
please give me detail of initial sizing of worm gearbox in Inch system with formulaes.
Good Answers: 183
Re: worm gearbox
03/09/2010 9:12 AM
Most economical solution to your problem:
1- google for worm gearbox manufacturers
2- look in their catalogues (technical side)
3- answer the questions with regard to load type, duty cycle, environment, aso.
4- make a request for quote asking at least 3 potential suppliers
5- make a choice considering the most important criterion for you
6- place the order (if you have the money)
7- enjoy the result which will be positive if you made the right choice.
Least economical solution:
1- google a source for the design of a worm gearbox
2- try to well understand the basics and principles
3- make computations and drawings
4- manufacture the prototype
5- test the prototype
6- optimize the prototype
7- make the gearbox to be used
8- be sorry about the money amount you lost.
Such products are standardized and manufactured in series or adapted to a special demand to a low cost.
Re: worm gearbox
03/09/2010 9:49 AM
The box should be large enough to hold all of the worms; thus
This compliments of member Ky, http://cr4.globalspec.com/thread/47367#comment491830
Re: worm gearbox
03/10/2010 4:11 AM
Someone's opened up a whole can of worms....
Re: worm gearbox
03/11/2010 2:14 AM
Okay, we hereby coin a new phrase for engineering problems: "Wow, that opens up a whole new can of worm gears."
[Maybe I should put my "Editor Crankshaft" moniker on that one.]
Anonymous Poster (1); Doorman (1); nick name (1); PWSlack (1); sbjdream (1); Tornado (1)
You might be interested in: Worms and Worm Gears, Metric Gears, Hypoid Gears
