Previous in Forum: I-Beams vs. C-Channels   Next in Forum: Elbow-Style Hinge Joint for Micro Struts
Ball Bearing Balls or Roller Bearing Rollers?
03/09/2010 4:19 PM
Do we get Stainless Steel, or non- magnetic "Balls" or rollers -the kind that are used in Ball-bearings, or roller-bearings?
Re: Ball Bearing Balls or Roller Bearing Rollers?
03/09/2010 4:22 PM
I'm not sure I understand your question. What is the application?
03/09/2010 4:31 PM
A magnet in the vicinity is - kind of disorienting the balls. And the magnet cannot be removed,
Good Answers: 143
03/09/2010 5:49 PM
You can certainly get nonmagnetic bearings. Be aware that not all stainless is nonmagnetic. If I were in your shoes, I'd call up the local rep for NSK or SKF and tell them my application and let them make a suggestion.
Good Answers: 27
03/09/2010 8:20 PM
Yes - there are bearings with ceramic rolling elements available from most OEM's.
I have no special talent. I am only passionately curious. Albert E
03/10/2010 3:57 PM
Thank you Sir for the information. I am an Electronics Engineer doing some R&d on generating electricity.
03/10/2010 2:59 AM
What do you mean by "dis-orient" the bearing balls. How can they become disoriented? The motor itself has very strong magnetic fields and nothing happens to the bearings. Pls explain.
03/10/2010 3:49 PM
Yeah, perhaps dis-orient is not the right word, what actually is happening is that in the absence of the magnet, the balls are in their place, and when the magnet is in position - their alignment goes.
Register to Reply 7 comments
Anonymous Poster (1); Kaisan (1); Loki (1); mohamed ebrahim (3); TVP45 (1)
You might be interested in: Roller Screws, Conveyor Rollers, Needle Roller Bearings
