Previous in Forum: Teflon Shaft Seal for Food-Grade Material   Next in Forum: Ligaments in Pressure Vessels
9 comments
Sourcing a Plastic Bolt
03/09/2010 8:14 PM
I am looking for a plastic hex bolt 1/4X20 1in long that I can torque to 75 inlbs, and handle temp. ranges -30 F to 120F
Re: Plastic Bolt
03/09/2010 8:23 PM
Good luck. This is for Nylon.
SIZE
ULTIMATE
TORQUE
MAX TORQUE
BEFORE DEFORMATION
YIELD
LBS.
BREAK
LBS.
YIELD
LBS.
BREAK
LBS.
256 ---NO TEST--- ---NO TEST--- 16 19 ------NO TEST------
440 24 In. Oz. 12-16 In. Oz. 38 41 45 50
632 30 In. Oz. 18-20 In. Oz. 65 69 91 97
832 5 In. Lbs 2-3 In. Lbs. 99 108 158 164
1024 6 In. Lbs. 2-4 In. Lbs. 139 149 187 257
1032 7 In. Lbs. 3-4 In. Lbs. 155 165 234 241
1/4-20 13 In. Lbs. 9-10 In. Lbs. 296 312 413 432
Re: Plastic Bolt
03/10/2010 1:26 AM
Vespel is great in compression (as for high-performance plastic bearings), but I don't know how good it is in shear and tension, both of which you need for bolts. Might be worth a look , though.
Re: Sourcing a Plastic Bolt
03/11/2010 12:21 AM
No plastic bolt can have such high torque values in 1/4 in size., Peek, Glass fibre reinforced Polyimide and PPS may have about 40% of that value. All of these will work at that temperature.
bioramani
Good Answers: 37
03/11/2010 1:32 AM
Can you describe the purpose? If I guess that "non-metallic / non-conductive" is a requirement, along with the torque, would ceramic do your job? Probably not: http://www.ortechceramics.com/Ceramic%20Screws,%20Nuts,%20Bolts%20&%20Washers%20-%20Ortech%20Ceramics.htm says that destructive torque for a 1/4-20 is only around 20 lb-in. Any chance of going up to 3/8-16? That gets destructive torque up level to 95 lb-in, according to the chart.
" Ignorance and arrogance have more in common than their last four letters. "
03/11/2010 2:45 AM
According to this table
From http://www.engineersedge.com/torque_table_sae.htm
Stainless Steel only just makes your requirement.
Note that although the higher Threads Per Inch bolts have a higher torque value, this does not mean a higher clamping force (disclaimer: I know nothing about this sort of thing).
Would this insulating kit idea be of any use.
03/11/2010 8:21 AM
It would be in your best intrest to start over by using fasteners as they were intended. Your requirement has painted you into a corner of a solid wall box, liability for the product would be a certain issue.
03/11/2010 8:58 AM
Hello Arnold Kay,
There is a supplier in Detroit called Suburban bolt that has what you are looking for.
75 in/lbs is = to 6.25 foot/lbs. is a lot of torque for nylon. I would suggest to use a nylon stand off sleeve and nylon washers for ground isolation and use an Aluminum screw through to plate connection. There are threaded nylon sleeves available as well. I don't know your application details... just a thought.
Try this link I think you will find it fascinating
http://www.nyltite.com/
Best Regards,
Tim
03/11/2010 12:49 PM
I've had luck with http://www.plasticnutsandbolts.com/screwsz.html. They have charts that you can scroll thru and find the one you need. Also you can try (Ryan Herco Flow Solutions) in Burbanks, Ca, they have an extensive supply of plastic bolts for all type of enviroments.
Best of Luck!
jhunter1972
02/16/2023 6:25 AM
That's great. When a source comes to light, please post the details here to help others.
Register to Reply 9 comments
Anonymous Poster (1); bioramani (1); jhunter1972 (1); lyn (1); PWSlack (1); Randall (1); Ron (1); Tim Hawley Master Mech (1); Tornado (1)
