Previous in Forum: Chlorine Adsorption and Granular Activated Carbon (GAC)   Next in Forum: Joining Glass and Steel
Surface Energy of Thermoplastics
03/09/2010 11:10 PM
I was reading something related to surface energy of thermoplastics. And I came across a self made conclusion: Amorphous thermoplastics have high surface energy while Semi-crystalline thermoplastics have low surface energy. I need to know am I right or wrong? and what is the reason behind a plastic having high or low surface energy? Please help me with your expertise.
Thanks in advance
Heman2727
Re: Surface energy of Thermoplastics
03/09/2010 11:24 PM
I don't have an answer for you, but I hope some one out there does. I'd really like to know myself. It makes me curious as to wether or not this fact might be useful in the field of alternative energy. Sincerely john clark
03/10/2010 8:52 AM
Hi heman2727,
Surface energy of materials is an important issue in the laminating industry, or for that matter, any time you want to bond two materials together.
Surface energy on relatively smooth surfaces is measured most commonly with "dyne solutions" (not an endorsement) - these come in solutions to test a specific surface energy range; some of the solution is spread onto the test surface and if it beads up after several seconds, a lower dyne value solution is tried. When the surface wets without beading up, you know what your surface energy is in dynes.
For an example, say I want to laminate a 3-mil PE film to a polyester film. I find that the dyne level is 32. This is too low for my adhesive to get a good bond with. What do I do? I can corona or plasma treat (again, not an endorsement) it or even use a chemical solution (two meanings!).
I do not know the relationship of surface energy between amorphous and crystallized polymers, but you should have enough links here to get you started.
Mike
03/10/2010 4:41 PM
Since you don't tell us why you want to know this, it's hard to provide answers.
If your goal is to bond two items together, just do a water break test on the surfaces.
Bondable (high energy) surfaces will allow the water to sheet smoothly over the entire surface of the adherends. If the water beads like a freshly waxed car you have low energy surfaces and treatments such as those suggested by Mikerho are indicated.
More information might yield more specific answers. Or not.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: Surface Energy of Thermoplastics
03/10/2010 5:01 PM
Please don't double-post, heman2727.
http://cr4.globalspec.com/thread/51569
Sometimes, it takes a while to get an answer. Patience is a virtue.
Register to Reply 4 comments
john w clark (1); lyn (1); Mikerho (1); Steve Melito (1)
