Previous in Forum: Surface Energy of Thermoplastics   Next in Forum: Silicon Carbide Whiskers
Joining Glass and Steel
03/10/2010 1:19 AM
I have a glass table with stainless steel legs that are glued on to the glass. what type of glue is best to be used ?
Re: Kscape
03/10/2010 3:03 AM
Glass cement can work.
Life consists not in holding good cards, but in playing well those you hold. ----J. Billings
Re: Kscape
03/10/2010 3:11 AM
Epoxy should be a good candidate. Pay attention to the application method so that you get a smooth layer of adhesive free of bubbles, without excessive adhesive that will moosh out beyond the actual joint. This is presumably a transparent table, so you don't want to look through it and see blemishes. This will probably take some experimentation/practice.
Good Answers: 137
Re: Kscape
03/10/2010 5:35 AM
Also I'd be inclined to break the glaze of the glass surface. Silicon carbide paper will do the job. The epoxy will stick a lot better then.
Cheers.........Codey
Re: Kscape
03/10/2010 4:38 AM
If the contact area is larger than, oh, say a 10mm circle at each contact point, then cyanoacrylate adhesive would be a good choice too.
Re: Kscape
03/10/2010 4:34 PM
Rear view window glue
Re: Joining Glass and Steel
03/10/2010 5:18 PM
If you wait long enough every possible adhesive will be recommended by someone.
Pick a reputable supplier and visit their web site or contact their technical folks and get their help.
Don't forget surface preparation. It's more/as important as adhesive selection.
If you do abrade the glass mask off the surrounding area with tape so you don't scratch exposed glass.
Good luck.
Anonymous Poster (1); Codemaster (1); Henscen (1); lyn (1); PWSlack (1); Tornado (1)
