Previous in Forum: Motor Class   Next in Forum: Standard Minimum Distance Between Busbars
Electromechanical Relay on SCADA
03/12/2010 12:46 AM
How can i give status of relay to control centre electromechanical old type it is possible or not (or it require contact multiplyers)
it is easy for NR relay for fiber or RS232/485 on IEC s and SPA bus but what abt old relay.
Re: electromechanical relay on SCADA
03/12/2010 2:58 AM
Two ways.
Either send the output to the relay to a SCADA point, indicating that the relay is energised, or take an input from one of the relay contacts to say that it has changed state.
03/12/2010 4:43 AM
Thanks for answer ...................
if the relay having two feature that is Over current and Earth fault....
so how come the Control centre people came to know feeder is tripped by OC only but it is actually trip by Earth fault.
if posiible plz guide me....
03/12/2010 5:08 AM
There are two inputs to SCADA. One is for overcurrent and the other is for earth fault. Discuss the inputs with the SCADA maintainers.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
03/12/2010 8:59 AM
And come back and register with the site, Guest! By registering with CR4, you can be notified automatically whenever someone replies to your question.
Anonymous Poster (1); PWSlack (2); Steve Melito (1)
