Previous in Forum: Bilateral or Unilateral   Next in Forum: PLCs vs. Microcontrollers
PLC Speeds and Microcontroller Speeds
03/12/2010 10:11 AM
which is faster in operation plc or microcontroler?
Re: plz help me find this ans......
03/12/2010 10:17 AM
It's not possible to say, because some PLCs can have high-speed digital input cards.
Maxim: "On a process plant, if it happens in less than 1 sec, it isn't real."
Good Answers: 266
03/12/2010 10:32 AM
Design characteristics of the plc components or of the microcontroller determine their speed. Most microcontrollers are design for a particular application speed will be part of its design in what application it used. Plc use all ready available components in most cases so will change with the industry. They could be the same speed one could be faster then the other which depends on the design.
Re: PLC Speeds and Microcontroller Speeds
03/13/2010 8:09 AM
To many variables to tell. The fastest in either topology will be for the time critical process to be interrupt triggered. With a microcontroller you can easily select an appropriate platform and program accordingly. In a PLC system you may have to sequentially scan all inputs and thus not select a process priority. But this can be a moot point if one works on a 100 kHz clock and the other a 100 MHz clock.
ozzb (1); PWSlack (1); redfred (1)
