Previous in Forum: I am having some challenges with earthing   Next in Forum: What happens when both ac and dc supply is combined?
30KW Motor cable selection
03/13/2010 8:46 AM
Will a 16mm X 4 Core cable be ok for a 30 Kw 380 Vac 50 Hz 4 pole motor ( DOL Starting)?? Distance from panel to motor is MAX 20 meters.
Re: 30KW Motor cable selection
03/13/2010 9:06 AM
The FLC of a 30kW motor at 380V may be in the range 53 to 60A.
A 4CX16sq.mm copper cable is sufficient for this application. But a 4CX16sq.mm aluminium cable is barely sufficient for this application.
I would suggest that you go for a 3CX25sq.mm armoured Al cable for this motor. There is nothing wrong in laying a 4C or 3.5C cable, but the fourth core is not required for the motor except for motor TB earthing, if the provision is available inside the TB.
Since it is not clear from your question whether the cable is armoured or flexible, it is better if the cable used is armoured.
03/13/2010 2:18 PM
Thanks, the cable is in copper and is flexible..
The only reason for the 4 core is that I have a a 20 meter length of 16mm x 4 core flex copper cable....non-armoured
Good Answers: 170
03/15/2010 9:58 AM
If the cable is not laid underground, then even a flexible, non-armoured cable would suffice.
07/24/2024 9:32 AM
British Standard 7671 needs to be in the toolbag...
Register to Reply 4 comments
electricalexpert65 (1); Electronaut (1); porky2009 (1); PWSlack (1)
You might be interested in: DC Motor Drives, Motor Controllers, AC Motor Drives
