Previous in Forum: Green Power and Amp Hours   Next in Forum: Pacific Ocean Becomes Plastic Ocean
Field-Modulated Generators for Wind Energy
03/16/2010 11:21 AM
hi can any one tell me the advantages of ac excited synchronous generator and a mosfet inverter, more specifically to its usage in field modulated generator scheme of variable speed constant frequency system for wind energy
Re: wind wind wind
03/16/2010 11:29 AM
It's probably that the output frequency and phase corresponds to the local mains, at whatever speed the rotor is turning.
Re: wind wind wind
03/16/2010 12:00 PM
So the speedly mainsifold is linking to the frequent phasyload of the rotaty discus?
Good Answers: 141
Re: wind wind wind
03/16/2010 3:39 PM
How is this coupled? Why MOSfet?
Plenty of room here
Re: Field-Modulated Generators for Wind Energy
03/16/2010 6:08 PM
MOSFETs typically drop less voltage than say transistors.
The On resistance of MOSFETs has become very low over the years.
Transistors and especially Darlingtons drop quite a voltage even when hard on, say a volt, at a high currents this represents quite a power loss. 10amps at 1volt is 10watts whereas 10amps at 10mΩ is 1 watt (I2R) if my catly arithmetic is right...
Good Answers: 15
03/17/2010 2:03 PM
I think what is intended here is that an HF or polyphase ac is modulated with the local freq (50Hz in your case) which then can be rectified in alternat directions to give a sine wave output at the modulation frequency.
Chas
capblanc (1); dvmdsc (1); PWSlack (1); user-deleted-1105 (2)
