Previous in Forum: CR4 Spell Check Workaround for Internet Explorer   Next in Forum: How to Delete Comments
Solar panels
03/16/2010 7:33 PM
Does anyone know what kind of glue to use making solar panels glueing copper pipe to aluminum so it would be conductive?
Re: Solar panels
03/16/2010 8:41 PM
Adhesives and Sealants
Chemical Vapor Deposition
Cleaning and Removal Fluids
Conformal Coatings
Die Attach Adhesives
Die Encapsulants
Electrically Conductive Materials
Encapsulants
Gels
LED Materials
Patternable Silicones for Electronics
Precured Gel - Pads and Parts
Primers
Semiconductor Fabrication
Silicon Lithography
Spin on Dielectrics
Thermal Interface - Pads and Films
Thermal Interface - Wet Dispensed
Electronics Solutions
Total Solutions for Electronics
Material, Process and Equipment Integration
Product and Application Development
Facilities Design and Engineering
Total Supply Chain Management
Equipment Alliance
Electronics Individual Services
Corporate Services Home Page
Product Resources
Find Products/Datasheets
Product Q&A
Find a Distributor
Applications
Applications Home
Automotive Electronics Applications
Technical Resources
Case Histories
News
Promotional Literature
Technical Articles
Selection Guides
Thermally Conductive Materials Tutorial
Thermally Conductive Adhesives Overview
Dow Corning® offers a variety of noncorrosive, thermally conductive silicone adhesives that are ideally suited for use in bonding hybrid circuit substrates, power semiconductor components and devices to heat sinks as well as for use in other bonding applications where flexibility and thermal conductivity are major concerns. The flowable versions are also ideal for use as thermally conductive potting materials for transformers, power supplies, coils and other electronic devices that require improved thermal dissipation.
Dow Corning® Brand ProductDescriptionFeatures
SE4420 Thermally Conductive AdhesiveOne-part moisture cureFlowable with moderate thermal conductivity; fast tack-free
SE4422 Thermally Conductive AdhesiveOne-part moisture cureHigh viscosity with moderate thermal conductivity; UL 94 V-1 rating; fast tack-free
SE4486 CV Thermally Conductive AdhesiveFlowable; one-part moisture cureFlowable with good thermal conductivity and controlled volatility (D4-D10 < 0.002); fast tack-free
SE9184 CV Thermally Conductive AdhesiveOne-part; non-flow; moisture cureModerate thermal conductivity; UL 94 V-0 rating; controlled volatility (D4-D10 0.003); fast tack-free
SE4400 Thermally Conductive AdhesiveTwo-part; semi-flowableLong pot life; rapid heat cure; self-priming
SE4402 CV Thermally Conductive AdhesiveOne-part; gray; heat cureModerate thermal conductivity; controlled volatility
SE4450 Thermally Conductive AdhesiveOne-part; gray; heat cureHigh thermal conductivity
1-4173 Thermally Conductive AdhesiveOne-part; low flow; grayRapid heat cure; high thermal conductivity
1-4174 Thermally Conductive AdhesiveOne-part; low flow; grayRapid heat cure; high thermal conductivity; contains 7-mil (178-micron) glass beads for bond line control
Q1-9226 Thermally Conductive AdhesiveTwo-part; semi-flowableLong pot life; rapid heat cure; self-priming
3-1818 Thermally Conductive AdhesiveOne-part; grayRapid heat cure and primerless adhesion to common substrates used in the electronics industry; UL 94 V-0 rating; contains 7-mil (178 micron) glass beads for bond line control
Q3-3600 Thermally Conductive EncapsulantTwo-part; gray; 1:1Rapid heat cure; long pot life; excellent flow; self-priming; UL 94 V-1 rating
3-6605 Thermally Conductive ElastomerTwo-part; gray; 1:1; medium viscosity; heat cureGood flowability
3-6751 Thermally Conductive AdhesiveTwo-part; grayLow modulus; low viscosity; heat curable; UL94 V-0 rating
3-6752 Thermally Conductive AdhesiveOne-part; grayRapid heat cure and primerless adhesion to common substrates used in the electronics industry; UL 94 V-0 rating
3-6753 Thermally Conductive AdhesiveTwo-part; gray; heat cureLow modulus; low viscosity; contains 7-mil (178 micron) glass beads for bond line control
PDF Links will download files in Adobe Acrobat PDF format. For technical information, or to download the free Acrobat Reader, go to Acrobat help.
Good Answers: 93
Re: Solar panels
03/16/2010 10:47 PM
I want the guest to send Lynlynch 2 hundred 70 dollars, and 57 cents for his answer.
Then I want the guest to either join up and help out, or pay 7 dollars and 50 cents everytime they ask a question, and get a good answer.
You don't get wise because you got old, you get old because you were wise.
Re: Solar panels
03/17/2010 10:09 PM
Well I believe you have wrapped this up. Great answer, when I ran across this I saved this to my own file for my dad.
jhunter1972
Re: Solar panels
04/02/2010 9:21 PM
Thermally conductive or electrically conductive?
Not safe to presume, even though common sense indicates thermal.
Anonymous Poster (1); jhunter1972 (1); lyn (1); Transcendian (1)
