Previous in Forum: Solder Throw in DC Armature   Next in Forum: Alternator Rotors and Reverse Power
8 comments
Siemens VFD Drive - Opening of Resistance
03/17/2010 6:26 AM
i have installed a vfd drive of siemens for 80 t crane in my company .
the matter is this ,that the resistance gets heat up very much after few operations and it opens .
so anyone pls give me their valuable suggestion to rectifiy this problem .
thankyou
Re: opening of resistance
03/17/2010 6:49 AM
It's taking too much current. Which means that one or more of the following applies:
  • The motor downstream of it is faulty.
  • The cabling downstream of it is faulty.
  • The winch speed is too fast for the load.
  • The winding drum friction is too high.
  • The load is too heavy for the winch.
  • etc.
Good Answers: 29
Re: Opening of Resistance
03/17/2010 8:08 AM
What is the fault code?
03/17/2010 8:16 AM
....and what does the Siemens specialist say on the subject?
Good Answers: 804
Re: Siemens VFD Drive - Opening of Resistance
03/17/2010 12:36 PM
To add to PWSlack's list:
  • VFD is not programmed per motor nameplate values (common error)
  • The "resistance" you speak of is Dynamic Braking Resistors, and they are over heating because they were not properly sized for the application and/or duty cycle.
  • They WERE properly sized per the original tender specifications, but you are EXCEEDING the designed duty cycle.
  • etc. etc.
In other words, you have not provided anywhere near enough information for anyone to help much. As was suggested, did you get someone from Siemens or the crane manufacturer to get involved? This is the type of thing that needs up close and personal investigation.
Belgium - Member - New Member
Good Answers: 21
03/18/2010 8:25 AM
I suppose it is the braking resistor that is warming up. Normally this comes from kinetic energy transfer to electric energy in the DC capacitor inside the VFD.
If there are more than one VFD's, you could connect the DC bus of the VFD to each other. This only works when one motor (VFD) consumes energy and an other motor (VFD) at the same time delivers energy.
Other solution,
  • increase the deceleration time,
  • mouting a bigger braking resistor (one with a bigger thermal capacity), keep in mind that the ohm value is the same.
  • better cooling of the braking resistor
03/18/2010 4:03 PM
I think that you are refering to the braking resistor, for your application I would increase the wattage of the resistor, and ensure that it is well vented, possibly some forced air cooling will help.
I also presume that the VF Drive is on the main travel, so I dont think that increasing the slow down time would be a good idea, from a safety point of view.
03/20/2010 1:43 PM
Please Visit the web site mentioned below. They are pioneer in India in designing resisters for above applicaions
There is nothing either good or bad, only thinking make it so -
03/20/2010 1:46 PM
The web site not included . please find it as www.nationalswitchgears.com
Register to Reply 8 comments
Joe Sparky (1); JRaef (1); Panneer Selvam (2); PWSlack (2); RDGRNR (1); rudy.leurs (1)
