Previous in Forum: Wi Fi Amplifier?   Next in Forum: Microcontrollers With Wi-Fi Capabilites
Popular Science - Weaponology - It is my dreams from childhood Engineering Fields - Agricultural Engineering - Now I am doing this Engineering Fields - Environmental Engineering - Its my motive to take care about
Zener Diode Effect in Series
03/17/2010 6:40 AM
Hi friends,
Can anyone help about the following???
How the zener diode behaves when it is put in series, like in the reverse bias mode?
Vishal Raut
Re: Zener Diode effect in the series
03/17/2010 6:51 AM
Sure you don't mean "forward bias mode"?
A Zener diode is usually used in reverse bias mode (cathode to positive); it won't conduct significantly until the Zener voltage is reached. In forward bias mode (anode to positive), it behaves like a "normal" diode. The forward voltage drop (Vf) depends on the particular device.
03/17/2010 6:56 AM
Good old Wiki....
03/17/2010 6:56 AM
If wired in one direction it will drop about 0.7v if wired the other way around it will drop the zenner voltage.
The best thing is to get a 3v3 zenner or similar a 1k resistor, a pp3 battery and a volt meter. You can then play until you are contented.
On some input circuits I use two 4v7 zenners wired in seried back to back across the input terminals to help remove spikes to protect the input to a microprocessor. so any voltage over 4.7 + 0.7 will be conducted regardless of the spike polarity (I realise that the series impedance is still fairly high and this doesn't provide sophisticated protection...but it helps in some applications)
Good Answers: 143
03/17/2010 7:39 AM
Del misguidedly said, "You can then play until you are contented."
As Henry Fonda said in Slim, "That's the matter." You may be among the last generation that thinks you can learn electronics by mucking about on the bench rather than by reading.
Register to Reply 4 comments
JohnDG (1); PWSlack (1); TVP45 (1); user-deleted-1105 (1)
You might be interested in: Bias Tees, Diode Arrays, Reverse Osmosis Systems
