Previous in Forum: COP and EER for Air-Cooled Chillers   Next in Forum: NPSHR 40000 Hrs for Centrifugal Pumps
Watertight Solenoid Valve
03/18/2010 2:25 AM
i want to watertight a solenoid valve having service of 250 bar air. since this valve is in the water, so when solenoid valve will in shut position then water ingress can be possible into the valve n can damage the actuating circuit of the valve.
how can i solve this problem
looking forward for effective response
Re: water tight solenoid valve
03/18/2010 6:12 AM
- Get a proper rated (IP ) solinoid valve
- House the valve in a sealed chamber
03/18/2010 8:06 AM
Why is the valve underwater? Would it not make more sense to mount it elsewhere?
Re: Watertight Solenoid Valve
03/18/2010 12:53 PM
There are NEMA and IEC specifications for submersible enclosures, which may vary with depth of submersion. The valve would need to have one (or possibly two) shaft seals to prevent the piped fluid from getting the electric parts, and a gland seal for cable entry into the enclosure.
03/19/2010 2:17 AM
thanks to all buddies i have Solenoid valve of IP65 n i want to utilize this as an experiment (since IP 68 is used for underwater applications). i m doing pipingwork for a "water park" n they need controlled air supply in a water tank. isn't there any sealing arrangement (besides as suggested) e.g any epoxy or glue type to prevent the electric circuit
03/19/2010 9:26 AM
Why the solenoid can not be taken out of water as PWS suggested? the outlets can go underwater but why the solenoid?
Anonymous Poster (2); piping_engineer (1); PWSlack (1); Tornado (1)
