Previous in Forum: Heater Element Corrosion   Next in Forum: Power Wattage Consumption
High Voltage Cables - Safety and Semiconductors
03/18/2010 11:29 AM
can any person explain me about the high voltage cables.safty of these cables and why we use simi conductor in high voltage cables,
thanks for you kindness
Good Answers: 804
Re: High Voltage Cables - Safety and Semiconductors
03/18/2010 1:52 PM
We use semiconductors in HV cables?
03/18/2010 2:21 PM
Please see previous threads on CR4 as this has been explained a number of times.
Good Answers: 42
03/18/2010 2:39 PM
The XLPE cable has a semiconductor layers provided. The main insulation of high voltage cable is done by extrusion and is sandwiched between two semiconductors. The semiconductor layers are essential to give proper contact between conductor and insulation. This will avoid partial discharge and progressive deterioration of insulation of the cable.
The purpose of the semiconductor layers is to influence the electric field strength within the insulation layer.
jack of all trades (1); JRaef (1); V.I.Abraham (1)
