Previous in Forum: High Voltage Cables - Safety and Semiconductors   Next in Forum: Photovoltaics, Net Metering, and True Up
Power Wattage Consumption
03/18/2010 1:27 PM
I'm trying to calculate the wattage a radar ultra-sonic device takes. The radar instrument is loop powered (4-20ma).
Data sheet only shows 24VDC with max 550 ohms.
P = V*I = 24VDC * 20mA = .48 Watts
Can someone please confirm instrument power consumption?
Re: Power Wattage Consumption
03/18/2010 2:36 PM
I would consider P-P, ERP, SWR loss. The mathematics becomes a little complicated. Consult a basic electronics or communications text.
03/18/2010 11:30 PM
Hai
What your said that is correct.But the loop power consuption varied based upon the loop current(4-20ma) .
But the max power is .48watts only.
Regards
GIRITHARAN.R
giritnsf@gmail.com
03/18/2010 11:32 PM
hai
Good Answers: 54
03/19/2010 12:34 AM
Not sure I understand your reasoning. For me the spec says power the device with 24Vdc across the 2 leads and the maximum load it can drive is 550ohm.
Inside the sensor there is a device that controls the current flow as well as some circuitry that controls that device. The circuit probably uses little current, so most of the power loss is across the pass element.
At 24V with max current (20mA) there will be 11V across the load and 13V across the sensors internal electronics. Power in sensor P = VI = 260mW , power in the load is P= i^2R = 220mW
So, my guess is that the power 480mW
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 141
03/19/2010 12:41 AM
When using the power formula: P= U*I - than put P in Watts, U in Volts, and I in Amperes. 20 milliamperes = 20mA = 0,020 A (Amperes)* times your voltage = 24 V makes 0,480 Watts or 480 mW (milliWatts)
Plenty of room here
Good Answers: 54
03/19/2010 2:15 AM
True, that's the total.
But some power is dissipated in the sensor and some in the PLC's load. It depends on what Rabat is trying to work out.
Register to Reply 6 comments
Anonymous Poster (3); dvmdsc (1); ffej (2)
