Previous in Forum: Electric Spark vs. Arc   Next in Forum: Alternators and Load Sharing
Lux Conversion
03/19/2010 12:30 AM
if the luxmeter give unit in lux, so how to change that unit to W/m2 at 254 nm
Re: how the equalization of lux and w/m2 at 254 nm
03/19/2010 3:52 AM
Bring in the efficiency of the light source in lumens per watt, and the distance to the illuminated surface, considering a spherical surface at that radius.
Re: Lux Conversion
03/20/2010 12:06 AM
As I read the definition of lux, it relates to the illuminance as perceived by the human eye. Since the lower limit of human vision is around 400nm, your wavelength of 254nm is way too short for the human eye to perceive, and the luxmeter should not respond to it, other than to indicate danger!
If your luxmeter is really measuring radiation of that wavelength, then perhaps it is missing an ultraviolet filter.
If there is indeed significant radiation at that wavelength, then you need eye protection to enter that area! The most painful thing I have ever experienced was eye damage from excessive exposure to ultraviolet light!
Re: Lux Conversion
03/21/2010 5:37 AM
The lumens/ watt capacity of all the lighting sources are different.
Visible light is between 400nanometers to 700 nanometers.The one mentioned by you lies in ultaviolet region and is harmful wavelength and should not be produced in open places.
normally Halogen lamps may give you max 14 l /watt
Light emmiting diods 100l / w
however lux level will depend up on application area
if you are a managment professional or youth who wants to start business contact for free help for your project including financial assistance through NGO in and around Pune India
dkwarner (1); kirannawathe (1); PWSlack (1)
