Sometimes I let the 95 Acura get low on gas, and it won't start.
I crack the fuel tank cap and hear a whish of air pressure, and it will start.
My theory is that the unvented cap creates a vacuum situation making it hard for the fuel pump to overcome the low fuel situation.
I cannot be certain my theory is perfect, however my procedure has worked, apparently, so I am passing it on as something you might try.
I probably ought to drill a hole in the gas cap for the Honda Acura to further test my theory, but I probably ought not run my car low on fuel either.
