Do we need to check standard flanges(ASME B16.5) as per appendix-2 of Section Viii Div.1, what if the standard flange fails as per PVElite in Bolt area requirements or bolt spacing, shall we consider it safe only because it is within the pressure temperature rating, also do we need to consider corrosion allowance in the flange thickness calculation?
Thank you
