Previous in Forum: Stud Lengths, Washers and Bolted Joints   Next in Forum: ASME Standards for Checking Standard Flanges
Butt Weld Valve vs. Flanged Valve
03/24/2010 1:38 AM
I have used one butt welded valve of class 300 for the Auxiliary steam system line. Now i have been asked to check that, wheather we can replace this butt welded valve with higher class (class 600) flanged valve. Please suggest whether this is possible or one should avoid the flanged valve in steam service. Vavle is located outdoor.
Pressure is 20kg/cm2 and design temp. is 345 degree C.
Re: Butt weld valve Vs Flanged valve
03/24/2010 4:28 AM
Before looking at the possibility please explain why is there a need to consider it.
Re: Butt Weld Valve vs. Flanged Valve
03/25/2010 12:07 PM
That is not a problem. Check your code books to be sure of the material and class some materials will only need 300CL. Flanged valves are great for mechanics because they can be changed out with 2 wrenches, 2 gaskets, and a few minutes(depending on the size). Butt welded valves make for more down time when they fail. As a side note, any bolted connections can make for a possible point of failure.
Good Answers: 203
03/25/2010 10:58 PM
When designing or repairing a welded piping system, unless for some reason unique to that particular system, it is always better to weld the piping fittings and use flanged connections for valves and other critical components which might have to be removed from the system at a later time. Taking a flanged piece out of the piping is much easier and faster than cutting out a butt welded one.
A good pipe-fitter and a welder can install two flanges on the corresponding pipe ends faster than they can set-up and weld the component into the piping. This is particulary true if it involves out of position welding.
In some instances it is much faster to weld the flanges onto the pipes in the welding shop, level the flange holes in the field and weld the other pipe-ends in the field. For a component that has butt weld ends, weld-neck flanges can be welded on it in the shop and installed with the bolts in the field. Shop welding is usually faster and of higher quality than field welding. This is particulary true if it involves out of position, weather problems, access problems, flammable atmospheres or other field type problems.
For steam use you should use flange covers to prevent any leaks from injuring personnel.
Going from a 300# butt welded valve to a 600# flanged one only requires installing 2ea 600# flanges on the existing piping to accomodate it. Be sure pressure rating of the other components is not going to be exceeded if you are also going to raise the operating pressure above 300psi.
11/09/2010 12:11 PM
As per Engineering Practice we should prefare welded connection over flanged connection in following design condition-(for safety purpose mainly)
Design pressure is "50 barg and above" and or Design temperature is "400 deg celcius and above"
Jeff.Parker (1); Lahane82 (1); old salt (1); PWSlack (1)
