Previous in Forum: ASME Standards for Checking Standard Flanges   Next in Forum: Pipe Paint
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Angular Twist
03/24/2010 5:15 AM
Hi All.
I would like to know what is the relation between radians and mm where radians is the measure of angle of twist. Any help will be good.
Varun Passi
Pathfinder Tags: bending moment twist
Re: Angular twist
03/24/2010 5:40 AM
What are the mm a measure of, and in what context?
Re: Angular twist
03/24/2010 8:18 AM
torando
the angular twist value the supplier gave is in radians which has been converted to mm in last output. to my knowledge its only the value of teh radians multiplied by radius of the object used. only on following the above method the value which he states in mm is found to be rite.
Varun Passi
Re: Angular twist
03/24/2010 5:49 AM
Did you forget simple geometry?
Re: Angular Twist
03/24/2010 8:16 AM
guest i've forgotten nothing wanted to know since its a relation between 2 different quantities.
Varun Passi
Good Answers: 137
Re: Angular Twist
03/24/2010 8:25 AM
Angle of twist in radian x radius in mm gives arc length (measured at same radius) in mm.
Cheers
Codey
Good Answers: 21
Re: Angular Twist
03/24/2010 12:15 PM
2*pi radians = 360 degrees
This wont tell you how many mm though cos it depends what the radius of your circle is, or arc if you haven't completed one full rotation.
Register to Reply 6 comments
Anonymous Poster (1); Codemaster (1); MACA (1); Tornado (1); varunpassi (2)
