Previous in Forum: Motor Terminals - Start and End Points   Next in Forum: Fluid Couplings and VVVFs
Cable termination problem
03/24/2010 5:16 PM
We used larger size of cables because of the voltage drop but are having problem to terminate the cables at both ends because of its large size. What is best solution for this problem?
Re: Cable termination problem
03/25/2010 7:24 AM
If you have the flexibility to extend the terminals you can use the adapter box for terminating the bigger size cables. it will give the easy for glands and connections even in maintenance period.
Reply to Forum Thread
