Previous in Forum: ISO and NAMUR mountings   Next in Forum: Difference Seriel and parallel interface
Level Transmitter Diaphragm Material
03/26/2010 5:53 AM
For a Level Transmitter with remote seals installed on a Caustic Soda Evaporator Tank, what Diaphragm Material is most suitable? Please note that on HIGH side Caustic Soda Concentration is 48% and temp is @ 140 Deg C and LOW side is connected to top of the tank where Saturated Steam with 13 Bar pressure is present. (High Temp. and Caustic Vapours may be present at low side)
Present diaphragm material was Nickel on both high & low sides, but LOW side has developed a HOLE in it. What about Hastalloy-C on this application? Any ideas?
Reagrds,
Best Regards, srzambre.
Re: Level Transmitter Diaphragm Material
03/26/2010 11:45 PM
316L ss will be sufficient for this application
03/27/2010 8:44 PM
No.... SS316L is not suitable for Caustic Application.
03/27/2010 8:06 AM
Tough call.
I'd be wary of 316SS at those elevated temperatures and concentrations. Marcello Picciotti's article in Chemical Engineering Progress warns against 316 at temperatures above 100°C due to stress corrosion cracking
http://www.allbusiness.com/management/4110394-1.html
Nickel 200 has been the standard for hot caustic.
DeRenzo's Corrosion Resistant Materials Handbook (4th Ed) has a table (pg 665) listing Hastelloy B-2 & Inconel 625 with very low 0-150um/yr corrosion rates in 50% boiling NaOH.
I wonder if the use of nickel with whatever its life isn't the cost of doing business, and that there isn't anything much better
03/27/2010 8:48 PM
Hi Carl,
Thanks for informative feedback. Any idea's for Hastalloy C-276?
Transmitter with Nickel Diaphragm will be a special order I guess....
04/06/2010 8:22 AM
PTFE-coated 'anything', really.
Anonymous Poster (1); Carl_E (1); PWSlack (1); srzambre (2)
