Previous in Forum: Balanced Taper Gauges   Next in Forum: Tungsten Inert Gas welding
Can A Lead Lined Tank Be Used To Store Sulfuric Acid?
02/06/2007 3:09 PM
Can a tank of capacity 1000 litres made on ground or elevated position for storing sulfuric acid??
rohitraj999@gmail.com
Re: Can lead lining be used in a storage tank for sulfuric acid???
02/06/2007 3:17 PM
I'm no chemist, but doesn't lead react with acids?
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
02/06/2007 4:41 PM
Is it concentrated sulphuric acid?
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: Can A Lead Lined Tank Be Used To Store Sulfuric Acid?
02/07/2007 12:39 AM
Do not use lead!
Plastic is probably the best all around choice, and is very commonly uses to store sulfuric acid in any concentration.
One link:
http://www.polyprocessing.com/html/safe-tanks.htm
Greg
02/07/2007 1:53 AM
If concentrated Sulfuric acid even Mild Steel would do.
Plastic is good for wide concentration provided temperature is not high.
FRP is good wide concentration and temperature range.
Lead would be good selection for dilute acid of high temperature. But difficult to line and maintain.
02/07/2007 9:46 AM
Apart from a change in electrical properties, the lead in a lead-acid battery is not affected by the acid, so I imagine lead would be OK to line a tank.
02/08/2007 12:21 PM
Yes--if %H2SO4 is<30
06/26/2011 1:09 AM
Lead can store sulphuric acid and doesn't react with it if it is concentrated. Most of the times lead react with the chemicals and damage the vessel as well as the chemicals inside it. So, it would be good for you if you could use plastic for the same.
lead answer @ leading way
Register to Reply 7 comments
bhankiii (1); ethanhunt3055 (1); Greg G (1); horace40 (1); mikey (1); MUKULMAHANT (1); yesyen (1)
