Previous in Forum: Automatic Door   Next in Forum: Suitable Cables for high harmonic (THD) generating machines
8 comments
Good Answers: 32
High Voltage Potting Compounds and Related Machines
03/27/2010 12:05 AM
Hello
I am interested in knowing all about High Voltage Potting Compounds and Related Machines.
I will like to have a system for potting high voltage transformers and high voltage electronic circuit for good thermal conduction and low corona leakage with excellent dielectric strength up to 50kV or more.
I am also interested in high voltage electrical tapes that can be used for wrapping high voltage circuits, cables and can shrink on heating to have a grip and can provide good electrical insulation.
Do you have experience in such area? You are most welcome to help out in gathering information and procurement of right type of chemicals and tools to implement this job properly. I will prefer small production line equipments that can be used easily. I will like to purchase such equipment that are meant for professional work. Vacuum filling, degassing, curing using heat or UV will be ideal.
Things I will like to encapsulate are.
High Voltage High Frequency (25kHz to 2MHz range) Mini Power Transformers
High Voltage Multipliers and High Voltage Regulator Circuits
HV Switches with lots of heat generating type that require heat sinks to transfer heat outside the casing and of course with high voltage safety
Chemicals that can flow in tight spaces and can bind
Chemicals that can be used to give shape for the final encapsulated block
Chemicals that can be used for coating and curing surfaces
Moisture resist
Very low corona leakage current
Hobbies - CNC - New Member
Re: High Voltage Potting Compounds and Related Machines
03/28/2010 1:37 AM
Whatever you use must be in some way an improvement over a tin can full of dielectric oil. Shell Diala AX is used in X-ray tubes and transformers quite successfully. If you find materials you describe, don't fail to let the world know. Oil is hard to beat.
Good Answers: 58
03/28/2010 5:48 AM
We have an adiabatic welding technology used for high-speed encapsulation of gas, fluid, or vacuum. Instead of sealing a container and leaving fill holes that later need to be sealed, the whole container is submerged in the fill media and the lid welded while submerged. This provides rapid and complete filling. Our current model will seal up to 8 linear inches in a few milliseconds, but the technology can be up-scaled.
09/17/2013 10:21 AM
Dear Prof. Shyam
Greetings!
We are also looking for high voltage potting compound and the agencies who can do potting on our high voltage units.
We have high voltage power supply module up to 5kV, which consists of dc-dc converter/multiplier ckt. I request you to kindly give above information if you have it.
Thanking you
with best regards
Pranav
Physical Research Laboratory
Ahmedabad
Good Answers: 32
09/17/2013 11:11 AM
Dear Pranav Adhyaru:
For 5kV design, let me have the power rating and its size and total heat dissipation along with critical dielectric strength need. Normally vacuum system, high dielectric potting compounds of high heat conducting capability and with little or no dimension distortion is required.
Have you tried Silicone potting?
09/18/2013 7:50 AM
Dear Sir, We have low power HV boards. one with 30microamp @ 2.5kV and other is 10microamp@ 5kV. We have used HV dc-dc converter with small peripheral electronics circuit to manipulate hv output characteristic. Total size of this PCB would be 110mm * 110mm. We would like to test PCB in ultra high vacuum(10 ^ -7 torr) for any degassing, corona discharge etc.Kindly advise.
Good Answers: 32
09/18/2013 10:23 AM
There are special low degassing potting compounds and you can also encapsulate and get the entire circuit welded in SS Case or other copper case leaving only exit points through ceramic high dielectric strength feed through.
Good Answers: 32
10/25/2013 11:57 PM
For 5kV you can fill Silicone and wrap it in high voltage electrical tapes.
02/10/2016 2:41 AM
Dear Sir
Which type of insulating material can be used in a sensing transformer for partial discharge test (up to 3 to 4 kv).
Regards,
Shiv
Register to Reply 8 comments
drbobwoolery (1); Pranav Adhyaru (2); Shiv singh (1); Shyam (3); welderman (1)
