Previous in Forum: 304 SS and mild steel, galvanic reaction?   Next in Forum: piping designing
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
IA capacity
03/27/2010 10:46 PM
Hi mates:
Could anyone tell me how to determine the IA (Instrument air) capacity for a plant?
Regards,
Anything that can go wrong, will go wrong
Re: IA capacity
03/28/2010 3:29 AM
Are you kidding? How would we know without knowing the:
  1. Size of the plant
  2. Number of instruments requiring air in the plant
  3. The amount of air each of the instruments require
My recommendation: Hire an engineer.
Re: IA capacity
03/28/2010 6:29 AM
Mikerho:
Tks for your suggestion. You seem to be so serious to me.
Give you a star... and thank you.
Re: IA capacity
03/29/2010 10:47 AM
Add em up bro
Use the calculator.
Re: IA capacity
03/29/2010 11:32 AM
Guest:
Adding what up? Have you ever done this before?
What is you have several control/pneumatic valves or thousand of them in your plant? And what do you mean my adding them up? How to size the IA back-up tank? What if the compressor fails? How to size the compressor capacity?
I mean where I should go from this?
Re: IA capacity
03/29/2010 12:23 PM
Please refer to the answer given @ #1 by Mikerho. First, determine size, number, and amount as suggested.
After you have those quantified, then follow @ #3. Tally em' up bro.
We cannot help you on the first step, not having seen your plant.
Your air supply must exceed your air demand with some margin of safety.
Re: IA capacity
10/04/2010 10:39 PM
Hi all:
If one factory demands ~200Nm3/h of compressed air. It means that we should have one or two air compressors at capacity ~300Nm3/h. Supposedly it is correct.
As common sense, do we need to design an air storage tank to backup if the power is interrupted?
With this capacity of air compressor, how is the approximately the capacity of the buffer tank? Is that Ok for it to be as ~300Nm3.
Regards,
Register to Reply 6 comments
Anonymous Poster (2); hien.nguyenquoc (3); Mikerho (1)
