Previous in Forum: Thread Galling and Materials   Next in Forum: Pump Design for Multi-Mode Operation
11 comments
Scissor Lift Design
03/29/2010 9:00 AM
i am designing a scissor lift for 15 tons of load and 1m stroke.overall dimension are 4.8m * 2m*1.5m.I am want to know which material should be used for this? & which factor i have to consider for design like bending,buckling etc?
This discussion was "closed" on 03/30/2010 7:49 AM. No new comments are allowed.
Message from admins:
Homework question answered.
Good Answers: 183
Re: Scissor Lift
03/29/2010 10:34 AM
According to the kind of questions it would be better if you ask some body else to do the design.
As a basic counsel do not use butter for the beams it is too weak.
Re: Scissor Lift
03/29/2010 10:45 AM
I'll be more to the point than nick name. You do not appear to be qualified to design a device which could inflict lethal injuries on a person, if poorly designed.
Get a competent engineer to do the design. Then the insurance company can sue him if an injury occurs.
Good Answers: 54
Re: Scissor Lift
03/29/2010 10:43 PM
Come on guys it's a homework question. So, Ravi, sit down and make a list of the possible options you have eg
Butter - For - It's readily available in India, has a pleasing color Against - not many tables published on mechanical properties, may not withstand temp extremes etc
Then, think about each possibility yourself, construct your own reasons for and against using it, think about how you could verify your choices. Have your own design roughed out then look at how other people have solve the same problem.
It's the journey, not the destination that counts.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Re: Scissor Lift
03/29/2010 11:24 AM
I'm with the others on this.
I have purchased several scissor lifts of various stroke/load combinations. There are several manufacturers that offer multiple combinations off the shelf. Your need will likely fit within standard products. Southworth is one company that offers a large array of lifts. Search "table scissor lift" instead of just "scissor lift" and you will get the stationary industrial lifts as opposed to the drive around lifts.
Because they are standard or semi-standard the safety interlocks, scissor sway, unequal load considerations are all worked out and proven. Since they are virtually off the shelf the cost is quite competitive.
Everything I know about opera I learned from Bugs Bunny
Good Answers: 141
Re: Scissor Lift Design
03/29/2010 10:54 PM
to lift 1 meter and a table of these dimensions, I should not build a 1 scissor lift. Not even a scissor lift. And if it must be a scissor lift, I should build one with 2 or 4 scissors. Your biggest problem will be the lift off. When down, a scissor lift has a terrible starting couple. That is why sometimes a second piston is used to overcome this. I should use some steel for the scissors. You have no space for cylinders? Or motorized spindle screws?
Plenty of room here
03/30/2010 5:09 AM
thanks for reply, i have done all static force measurement.now i want to check it against
bending & buckling so i want exact material property by which i do all this thing.
& u are right that i have to go to build 2 scissor because large load & i have a enough space for cylinder.
03/30/2010 5:39 AM
Excuse me for anonymous reply: my email is still waiting for registration. What do you mean saying "Your biggest problem will be the lift off. When down, a scissor lift has a terrible starting couple." Is it a large force on a piston? This is more obvious to me due to small lever of this force in the lowermost position. Having a long lecturer experience I try to be correct in terminology and your's phrase is significant for my English. Did I understand you correctly? Ernik, St-Petersburg, Russia http://unimech.narod.ru
03/29/2010 11:31 PM
You are surely from India. Do care about the national pride and do not ask such disgraceful toooo simple basic questions. You will never get the answer, but the right responses as you have got here.
I am with nick as well as lyn. You are not design engineer. Do not think of designing anything. You will get what you want, in Indian market with ample choices. Just select appropriate and purchase one.
03/30/2010 4:43 AM
I am neither from India nor mechanical engineer, but it is better to ask instead of not asking and making mistakes.
03/30/2010 5:43 AM
Yes my friend, it is better to ask than to make mistakes.
But, while asking, it should be clear that you have done some efforts and want further guidance or confirmation.
Asking toooo basic questions like, what material should be used, and what material properties should be used shows that no real efforts are done. Certainly, one will not use copper for the lift. Obvious choice will be some grade of steel or may be even stainless steel. Any designer will not ask such basic questions. Material properties can be found out from various standards or hand books. If OP is really a designer, he can surely find out this information.
If the OP is asking such basic questions, do you feel that the product he designs will be safe?
I am from India. Many participations on CR4 are from India. Unfortunately percentage of such unprepared / immature questions is more from India. Thats why my feelings.
03/30/2010 6:16 AM
For sure everything will be better next time, that is why engineers exist.
Register to Reply 11 comments
Anonymous Poster (3); DaveB (1); dvmdsc (1); ffej (1); gsuhas (2); lyn (1); nick name (1); ravi4mech2008@gmail.com (1)
