Previous in Forum: Luna Lift   Next in Forum: Scissor Lift Design
Thread Galling and Materials
03/29/2010 8:22 AM
Are ther any rules of thumb/best practices "in print" for mating threaded fasteners to prevent cross threading/galling?
Re: Thread Galling & Materials
03/29/2010 8:57 AM
03/29/2010 9:15 AM
Anti seize compounds are fine for reducing galling.
But, galling and cross threading are two different things. No amount of anti-seize will prevent cross threading, as that is caused by the person starting the threads in the first place.
03/29/2010 10:23 AM
I agree & thanks!
The only way to know is to apply what you learn!
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Thread Galling and Materials
03/30/2010 4:32 PM
Considering that the relevant geometries are correct, certain fastener materials and combinations thereof are more conducive to galling than others. Speed of assembly can sometimes play a role too. For example, make sure that you slow down when tightening stainless fasteners.
Galling is particularly troublesome with "fitted" bolts. I've often seen otherwise well-trained individuals feel that they were doing a good job by using a light rubber mallet to "help" a fitted bolt into its respective hole .
The problem with this is that there was a reason why the bolt didn't go in easily. Even the slightest amount of material picked-up while the bolt is "helped" into the hole will set the stage for disaster. Subsequent turning of the bolt in the bore will likely turn an ugly situation into a horrendous one. Keep the mallets, hammers, pipe wrenches, and cheater bars far, far away during installation. Do not apply torque until the bolt is fully into the hole. Unless one is working with a blind hole, make sure that the bolt does not turn when torquing the nut.
Remember: If you feel that you need "help" to get a fitted bolt in, address the problem before you start beating'n bashing, regardless of how "careful" you intend to be!
Best regards, HeviiGuy
BoltIntegrity (1); lyn (1); Mikerho (1); rls1230 (1)
You might be interested in: Threading Dies, Threading Tools
