Previous in Forum: Pocket In Pump Out Line?   Next in Forum: Piping Class
Chilled Water Network
03/31/2010 8:13 AM
Dear All,
Thanks for this interesting forum... hope to find a solution for my question below:
Does it exist international standards or handbooks for DCP buried pipes? like minimum cover, min distance between supply and return, min dimensions of valve chambers...
thanks a lot
Good Answers: 141
Re: Chilled Water Network
03/31/2010 3:41 PM
How long is the run? What is the capacity pumped? What is the diameter? What is the pressure? What is the Isolation of the pipe and what is the medium and temperature where your pipes run through?
Plenty of room here
03/31/2010 3:54 PM
maximum data are known of dcp (max run,...) ... Would like to know the available standards if existing.
Good Answers: 141
03/31/2010 10:40 PM
Try here maybe: copy and paste www.tradekorea.com/products/DCP_pipe.html
Plenty of room here
04/01/2010 12:37 AM
thanks but nothing there.
just note that i'm even prepared to pay for guidelines, handbooks...
04/02/2010 1:10 AM
Check ASHRAE /Carrier hand book. Details may be available. Regards. Dr.Ram
Good Answers: 18
04/01/2010 7:13 AM
Hi FARESMOTORS,
If you check out any pipeline manufacturers web site you will find the answers to your questions. Try ''Durotan'' or ''Aegis'' for a start. They specify the depth of cut and cover as well as valve chambers and provision for expansion/contraction etc.
Good luck,
Massey.
If it ain't broke,leave it well alone .........until it comes looking for you!
04/01/2010 7:24 AM
thanks
I checked them but nothing related to the requested subject.
Register to Reply 7 comments
dvmdsc (2); FARESMOTORS (3); Massey 726 (1); mrswamy (1)
