Previous in Forum: Chilled Water Network   Next in Forum: Presentation on FEA
Piping Class
03/31/2010 11:10 PM
Dear All
Can anyone explain what is this class related to Piping (ie: 600#, 900# etc). Is it related to temperature and pressure of the fluid service? Whether there is any difference between class of pipes, valves and flanges? Because I hav seen some class like 800# valves but not such a class with pipes...
Re: Piping Class
04/01/2010 4:25 AM
The classes are combined temperature pressure ratings (ASME B16.34)
Flange B16.5 (table 2 gives the pressure temperature ratings for class 150 to 2500 depending on the material 1.1 to 3.16)
Piping class B31.3 (process piping guide),
Next portion is the WOG rating (Water, Oil gas rating) this is different from the class and belongs to cold fluid ratings that the valve can handle. Note that the ANSI/ASME ratings are more of flange oriented.
Then is API 602. The class 800 does not figure in ASME but does in API.
API 602 Section 4 :
"Class 800 is not a listed class designation, but is an intermediate class number widely used for socketwelding and threaded end compact valves." (Section API 602)
4.1.2 Interpolated ratings
Pressure/temperature ratings for Class 800 shall be determined by the equation:
P8 = 1/3 P6 + 2/3 P9
where P8 is the pressure at the specified temperature, expressed in bar3, for Class 800 rounded to the nearest (10 kpa);
P6 is the listed pressure, at the specified temperature, for Class 600, expressed in bar;
P9 is the listed pressure, at the specified temperature, for Class 9004, expressed in bar.
Re: Piping Class
04/01/2010 7:27 AM
Thanks very much guest....
Good Answers: 61
Re: Piping Class
04/01/2010 1:41 PM
For a simple answer for flanges check this link:
http://www.scsenergy.com/scsdataflgrating.htm
Do it once and do it right
Register to Reply 3 comments
Anonymous Poster (1); hakr5 (1); PennPiper (1)
You might be interested in: Piping Services, Piping Systems, Heat Pipes
