Previous in Forum: Pelton Turbine and Specific Speed   Next in Forum: Thermally Conductive Plastic for a CIP Thermoforming Application
Torsion Spring for Medical Device
04/06/2010 8:42 AM
Hello out there; I am trying to locate a small Torsion Spring , approx, 3/4 to 1 in. in dia. 3/4 in. deep, with 1/2 in dia for shaft. Torsion strength , 20 to 30 Lbs. for Med device.
Good Answers: 15
Re: INVENTMED
04/06/2010 8:51 AM
Have you tried going to any spring manufacturer websites?
such as this?
downhill slide to 112 (damn memor.)
Good Answers: 29
Re: INVENTMED
04/06/2010 9:40 AM
Here's where I go for mine sometimes.
Re: Torsion Spring for Medical Device
04/07/2010 1:47 AM
If you want a top level supplier who understands the medical device needs, call these folks, they have bailed me out many times.
Motion Dynamics
231 865-7599
motiondc.com
Chris Witham or tim Holt would be the starting point. They have helped us through R&D and volume production with many designs.
Steve
Good Answers: 109
04/07/2010 2:52 AM
Hi,
in the last ? years I did design many different flexures - most highly specialised so I expect that I can give you a solution if you don't find what you need.
RHABE
04/07/2010 12:02 PM
Torsion spring produces torque not a force. If you define a force you should specify the spring arm length that the force is acting on. Added to it you should specify the spring angular deflection under the force or forces. Next you should define the number of loading cycles (fatigue design) if applicable. etc.
http://sites.google.com/site/israelkk/home
Good Answers: 29
Spring Theory
04/07/2010 10:38 PM
You are right. Some of RHABE's products seem impressive though. Very specific jobs I think. Try to use the existing supply houses if you can. Custom jobs can kill you on the tool-up unless your expecting a volume run. Good luck. I,m on my home laptop at the moment; someone let me know if it's any smarter.
Anonymous Poster (1); ddk (1); israelkk (1); RDGRNR (2); RHABE (1)
