Previous in Forum: How KERNEL POLYNOMIAL EQ. decides hyperplane of SVM.   Next in Forum: Incomer sizing calculation for a 3phase 4 wire 415V 50Hz switchboard
how to detect/test a rotor defect?
04/08/2010 6:14 AM
what test can be done to detect a rotor defect(broken rotor bar)?
what are the sympton that can be observed from the motor that are having rotor problem?
thank you.
Good Answers: 29
Re: how to detect/test a rotor defect?
04/08/2010 8:12 AM
This is sort of a vague question but I'd think the first sign of trouble would be excessive heat or vibration or both.
Good Answers: 60
04/08/2010 9:03 AM
more information please
describe the rotor
describe the fault
its dificult to give you an answer based on the limited information given
04/13/2010 8:05 AM
Hello KevinL,
good option for detecting broken or cracked rotor bars of motor on-line and under the load is instrument with MCSA or motor current signature analysis.
Sometime vibration alalyzer can identifies rotor bar defect with varuing magnetic field and vibration around running speed or * haystacks* and around high frequency vibration known as rotor bar pass frequency.
People with expirience can see bad rotor by simply swinging needle of amper meter.
Good luck !
Register to Reply 3 comments
Panta SD (1); peterg7lyq (1); RDGRNR (1)
You might be interested in: Bar Code Software, Rotor-Stator Mixers, Bar Code Cards
