Previous in Forum: Forming LARGE Concrete Walls   Next in Forum: Concrete: Rebar or Fiberglass?
10 comments
Foundation Pilling
04/08/2010 6:49 AM
Why we always start with pilling before excavation ?
Good Answers: 266
Re: foundation pilling
04/08/2010 6:57 AM
To make a the aches and pains of the previous excavation go away!
04/08/2010 6:58 AM
04/08/2010 11:02 AM
Ditto
04/08/2010 7:02 AM
Presumably because the piles go much deeper than the excavation?
Good Answers: 19
04/08/2010 7:11 AM
It is not always the case that piling is before excavation.
However, when it is, a good reason is that it is easier to pile from ground level than from in a hole. For instance, how big a crane do you need to lift a piling rig into an excavation? It is cheaper to pile and then do the digging.
omw7
04/08/2010 8:05 AM
thanks for your answer ,i m a junior architect ,i was wondering if this will not damage the pile
Reply Off Topic (Score 6)
Good Answers: 60
04/08/2010 12:26 PM
how would digging a trench say 3 metres down going to affect a pile thats some 15 metres down? and once the trench is filled back in the whole question goes away.
are you sure your an architect? i am a mechanic and i seem to know more
Not wishing to be rude
Good Answers: 19
04/08/2010 8:07 PM
Generally, the contractor is quite careful not to damage the pile. Although the pile is about 500mm diameter and it would take quite alot to damage it. And even if the bit above the final excavated level is damaged, this is not a cause for concern as the pile will be nibbled later to bring it down to the final pilecap level.
omw7
Good Answers: 60
04/08/2010 9:01 AM
from what has been said the assumption is clear
if your moving a piling machine around a building site, its easier to move ove flat land than to move over land with lots of holes in in it
obvious really
Re: Foundation Pilling
04/09/2010 7:23 AM
We don't start always with piling before excavation in general practice. where it needed we do exactly the same what you ask.
Anonymous Poster (2); lyn (1); Mikerho (1); omw7 (2); ozzb (1); peterg7lyq (2); PWSlack (1)
