Previous in Forum: Looking for a Reminder/Alarm Which Prompts Me When I Turn Off PC   Next in Forum: ANSYS 11 to Linux
10 comments
Protection for Power Point Presentation
04/10/2010 12:24 PM
Hi, I have a Power Point Presentation made in Windows 2007 and I would like to share it with others over the Internet, but I don't want anyone to modify it. What can I do to protect the file?
Good Answers: 53
Re: Protection for Power Point Presentation
04/10/2010 3:32 PM
You can save it as a read only with password protection. But there will still always be ways to plagiarize and/or modify the intellectual property of others.
04/10/2010 3:57 PM
© Then, litigate.
04/10/2010 4:24 PM
Keep it at home and no one will modify it.
best regards.
h.ekhlas@gmail.com
04/10/2010 10:34 PM
There is no perfect way, but I would save it as a PDF for distribution.
04/11/2010 12:00 AM
I used to save a copy of all my files (PPT, DOC, XLS, .. etc.) in PDF formats through a software like "Adobe Acrobat" which will install a printer appears to you just you click "File" then click "Print" and select that "Printer", then share the files with any of others.
04/11/2010 2:50 AM
But there are softwares available, which can convert back pdf files to its original format.
But converting those to pdf will protect the files from most of the people, who do not know about these softwares.
Only way to protect the files from modifications is to print each slide on paper. Then scan these papers to pdf file. This file you can share with confidence, as even if some body tries to convert back these pdfs, he will get only images. he will not get those in ppt / word or whatever was the original format.
04/11/2010 2:58 AM
It's a nice idea but it does not work. One simply uses OCR (Optical Character Recognition) software, the latest versions of which can read pdf files as well as scanned images, to convert back to the original image and text content. There is simply no way of protecting against this.
04/11/2010 12:10 AM
You can save it as a PDF and use password protection that will allow you to see exactly who opens the file when and where.
Try Mediafire.com ..it's free
04/11/2010 8:53 AM
Hi... you can save your files as powerpoint show. In this way, they can't edit this one.. If you are planning to print it as pdf file, I suggest to limit or restrict the access of the file.. you can even disable printing, editing, and many others..
04/11/2010 2:59 PM
u juts make it as a video file by movie maker then share it. nobody modify it. subhajit
Register to Reply 10 comments
Abdel Halim Galala (1); Ace Boeringa (1); Anonymous Poster (2); gsuhas (1); HarryBurt (1); hkian (1); JE in Chicago (1); lyn (1); phph001 (1)
