Previous in Forum: Fuel Cell or Diesel Gen Set?   Next in Forum: Number Riddles
10 comments
Good Answers: 109
NIKON Coolpix 950 Troubleshooting
04/11/2010 5:10 PM
Hi,
I have and used since nearly 10 years a NIKON Coolpix 950 -
very outdated now but still very useful as there is a possibility to focus to below 2 cm distance,
and the thread matches to the Leitz eyepiece of my microscope, so very easy to attach with nearly unlimited possibilities,
and I matched an old (military) Zeiss eyepiece to the lens so I can take photos of very small objects everywhere without the need of a microscope.
The camera did not come to life again after not being used for 3 months.
No sign of any life neither with fresh batteries nor with mains adaptor nor with both nor letting it charge (?) its internal battery for a day with both batteries and mains adaptor connected.
I serviced the mode-switch - no positive result. I found some useful advice including an official manual for assembly, measurement, adjustment and reassembly. Useful for disassembly and reassembly.
I disassembled the covers to get access to the electronic boards.
There seems to be no power at none of the needed voltages but I am not really sure as not disassembled as far as necessary for a clear measurement.
As the voltage is stabilised (naturally) and protected by shutdown there may be active shutdown of power or simply no power by failed connectors or wiring or failed backup battery.
Anybody out there who knows more about this problem?
Is a functional backup battery a necessity for switch-on?
Thank you for help
RHABE
Good Answers: 243
Re: NIKON Coolpix 950 quit working, possible solutions? My cat helps but no resu
04/11/2010 7:51 PM
Many of these cameras have an interlock kill switch to shut camera off if the door to the memory card is open. This is supposed to kills power when you remove the chip so you don't fry the chip. can you see if that is somehow activated?
milo
Good Answers: 109
04/12/2010 4:42 AM
Thank you for the reminder,
this Coolpix tells me: "no memory card" if the door is not closed.
But may be the memory card is short circuiting the camera, which in turn will shut down all power and not show any sign of life.
RHABE
Re: NIKON Coolpix 950 Troubleshooting
04/12/2010 3:45 AM
I think the problem is the the wrong sort of cat on the paperwork...have you tried different cats?
(Seriously, I have no sensible input, these tiny consume electronics devices beat me most times these days...but if they do, then they feel my wrath and get used for target practice. Not an entirely satisfactory solution admittedly)
Good Answers: 109
04/12/2010 4:47 AM
She is a Queen-Cat and will never allow "her" places to be occupied by others.
From time to time she is inviting some of the cats from unknown neighbours to come to a visiting party.
But only under her rule and terminated by Queen the Cat after a short time.
Any other cat will be torn to pieces beginning at the ears.
So very sad: advice cannot be tested.
RHABE
04/13/2010 3:03 AM
I can't help with the Coolpix, but, I can recommend the Ricoh Caplio R range which have a 1 cm macro mode. This was taken with an R5
It's the inside of a toggle switch (about 8mm x 3mm) which was failing.
The current model is the R10 and is about $300.
Good Answers: 97
04/13/2010 10:47 AM
RHABE,
Have you tried NIKON service center?
There may be a a free repair in it for you, depending on any recalls
CRTL-Z
04/13/2010 11:18 AM
I have a coolpix 950 also, and a few years ago, after about 17,000 photos, I began to have problems with the camera not wanting to turn on when I rotated the switch. Took it to a service center and the diagnosis was it needed a replacement switch barrel. That fixed the problem.
This solution sounds simple-minded, considering the info you have provided, but consider that letting the camera sit unused for three months may have permitted a slight panina to form on the contact surfaces of the switch. That, combined with contact wear (you did not mention the number of photos you have taken, indicating the relative "age" of the camera), could have created the problem where the camera won't "come to life."
It might be the rotating switch.
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
04/13/2010 10:42 PM
Don't know about their cameras but do know Nikon used cold soldering on many of their early total station circuit boards....check relays (if you can find them)?
Temperature fluctuations caused the solder to separate from the board.
Prophet Freddy has the answer!
Good Answers: 109
04/15/2010 3:03 PM
Thanks to all for your advice,
I deeply dug into the electronic interior and found the rechargeable backup battery:
Sanyo ML12220, see: http://www.abcde.de/data/ml1220.pdf
So either this is dead or the charging circuit is dead or it has lost most of its charge by non-frequent use and batteries not in place.
Momentary voltage is 0.7 V.
Nominal voltage is 3V.
Capacity is 15mAh.
Recommended charge/decharge with 0.1 mA or 3.1 +- 0.15V.
The ugly situation is going on that all the electronic boards had to be disassembled to get access. I have no idea if I have success of reassembly. Considering the spent time this is a fascinating hobby.
In the pic below all disassembled parts are shown and on the right circuit board a white square on the metallic shield is in the place where below the shield the battery is located.
In the photo below the shield is removed and the battery with its blue shrink tube visible.
RHABE
04/15/2010 3:22 PM
Great detective work.
I presume that you have concluded that the battery is kaput. You might try an experiement to see if you can check out the rest of the system.
If you have access to a regulated DC power supply, you might be able to "jumper" a 3.0 volt source around the battery to see if the system comes back to life. Choose a moderate current limit so you don't run the chance of frying something. Even if the charging circuit is defective, that should still get you some action.
If you get "life", then all you need to do is change out the battery; otherwise, keep looking.
note: you might be able to purchase replacement pc boards from some Nikon dealters, or Nikon itself.
Register to Reply 10 comments
Duckinthepond (1); John FS (2); Milo (1); Randall (1); RHABE (3); Unredundant (1); user-deleted-1105 (1)
