Previous in Forum: Discolored Wires   Next in Forum: Seminar
Hyundai Vertical Motor
04/14/2010 2:08 AM
Dear All,
We have Hyundai Motor position is vertical speed is 3600rpm, 250kw, using antifriction bearing DE # 6218 C3, NDE # 7218A. one of the bearing got seized and damaged (DE side) we are going to sleeve the housing but I would like to know what is the required interference fit between bearing to housing and bearing to shaft for both bearings. your advice is highly appreciated
Good Answers: 27
Re: Hyundai Vertical Motor
04/14/2010 4:33 AM
Shaft and housing tolerances
Shaft tolerances and resulting fits
Tolerance e7, f5, f6, g5, g6
Tolerance h5, h6, h8, h9, j5
Tolerance j6, js5, js6, js7, k4
Tolerance k5, k6, m5, m6, n5
Tolerance n6, p6, p7, r6, r7, s6, s7
Calculations and graphics presentation
Housing tolerances and resulting fits
Tolerance F7, G6, G7, H5, H6
Tolerance H7, H8, H9, H10, J6
Tolerance J7, JS5, JS6, JS7, K5
Tolerance K6, K7, M5, M6, M76
Tolerance N6, N7, P6, P7
Fits for inch bearings
Modified shaft diameter deviations g6, h6, j5, js5, k5
Modified shaft diameter deviations k6, m5, m6, n6, p6
Modified housing bore diameter deviations H7, J7, J6, K6, K7
Modified housing bore diameter deviations M6, M7, N7, P7
Or possibly easier, go here and in the space at top left that says "Product Search" type 6218 (or anything else you fancy) then press OK. Follow the instructions and all will be revealed.
I have no special talent. I am only passionately curious. Albert E
04/14/2010 4:41 AM
thanks for you, i have try it but i could not get required fit, if any body could help in this regard.
04/14/2010 9:12 AM
Bearings are tricky issues particularly when it is a vertical motor.Pl check with bearing manufacturers and get their help.SKF normally lend a good hand when such problems are taken to them
04/14/2010 11:13 AM
Why can't Hyundai help directly?
Register to Reply 4 comments
Fahad (1); Kaisan (1); nesubra (1); PWSlack (1)
