Previous in Forum: Starting an Instrumentation Business   Next in Forum: Stand Alone Unit Control Panel (UCP) Location
Electrical Wiring
04/14/2010 6:35 AM
how battery get dicharged and wat is der in battery and also why do we use grd in simple wiring system wat is key role of grd in wiring
Re: Electrical Wiring
04/14/2010 7:09 AM
A battery gets discharged because:
  • The energy required by the load during the time that the load is switched on exceeds the energy stored in the battery
  • The battery's condition is such that it cannot convert all its stored energy into electrical power to support the load.
Ground, or earth, is a system of safety conductors, designed to operate the circuit protective device(s) and disconnect the circuit from sources of power in the event of a fault downstream of it.
Good Answers: 29
04/14/2010 10:14 AM
Try this site and follow the technical resources link to learn more about batteries.
Good Answers: 60
04/14/2010 2:02 PM
peterg7lyq (1); PWSlack (1); RDGRNR (1)
You might be interested in: Wiring Ducts, Battery Holders
